Einleitung
This guide shows you how to replace the headphone port.
Was du brauchst
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
Detach the cover with your fingers
Gently wedge the plastic opening tool under the ribbons where each of the three cables are connected, and gently lift up to detach the cable.
Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
Place the plastic opening tool under the upper left corner of the headphone port, and lift up.
Remove the headphone port with your hands.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
My g4's headphone could only produce sound on one side. So i bought a new headphone jack from ebay and replaced it. The problem still persists. Does this mean it could be a motherboard issue?
Or a headphone issue. You did try a different pair of headphones?
i did the same as pholklorr with my g4 but bought oem and still doesn't work you can only hear it from one side
Great! My headphone port couldn't hold my headphones anymore because of wear & tear (they kept falling out) but this guide and a 6 dollar ebay-item fixed it! Thanks a lot.
