Zum Hauptinhalt wechseln
Canon EOS Rebel T5 Image Sensor Replacement
Was du brauchst
  1. Canon EOS Rebel T5 Image Sensor Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 2, Bild 1 von 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Image Sensor Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 4, Bild 1 von 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 5, Bild 1 von 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 6, Bild 1 von 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 7, Bild 1 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 7, Bild 2 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 7, Bild 3 von 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  8. Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  9. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 9, Bild 1 von 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  10. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 10, Bild 1 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 10, Bild 2 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 10, Bild 3 von 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 11, Bild 1 von 1
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
  12. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 12, Bild 1 von 1
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 13, Bild 1 von 2 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 13, Bild 2 von 2
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 14, Bild 1 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 14, Bild 2 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 14, Bild 3 von 3
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
  15. Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: Schritt 15, Bild 1 von 2 Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: Schritt 15, Bild 2 von 2
    • Remove the three silver 3mm Philips #000 screws from the image sensor holder.
    • Remove the image sensor holder.
  16. Canon EOS Rebel T5 Image Sensor Replacement: Schritt 16, Bild 1 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 16, Bild 2 von 3 Canon EOS Rebel T5 Image Sensor Replacement: Schritt 16, Bild 3 von 3
    • Remove the three remaining silver 3mm Philips #000 screws from the image sensor.
    • Be careful not lose the springs underneath the screws on the image sensor
    • Using your fingers, lift the image sensor from the device.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Brown
846 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 16-4, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Mitglieder
16 Anleitungen geschrieben
3 Kommentare
Thanks for the post. I was able to take this apart without damage to any of the camera parts. I am wondering if you happen to have the data sheet for the camera sensor, 704f? I cannot seem to find one.
Dawn - Antwort
Hi. I do not see where it explains the calibration of the Sensor. Could you give me some reference about that?
ivanram - Antwort
I reassembled on the camera no longer powers on, i checked disassembled again, checked for loose wires, ribbons, everything looks perfect and still it’s completely dead.
Edward Perkins - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 47
Insgesamt: 7,579
