Zum Hauptinhalt wechseln
Xbox 360 Controller USB Cord Replacement
Was du brauchst
  1. Xbox 360 Controller USB Cord Replacement, USB Cord: Schritt 1, Bild 1 von 1
    • Remove the tamper seal sticker from the back of the controller.
  2. Xbox 360 Controller USB Cord Replacement: Schritt 2, Bild 1 von 1
    • Remove the seven screws from the back of the controller.
  3. Xbox 360 Controller USB Cord Replacement: Schritt 3, Bild 1 von 1
    • Separate the front and back face-plates of the controller.
    • Use spudger or plastic opening tools if necessary.
  4. Xbox 360 Controller USB Cord Replacement: Schritt 4, Bild 1 von 1
    • Remove the Tumblers from the front face-plate.
    • Do not disconnect the tumblers from the circuit board.
  5. Xbox 360 Controller USB Cord Replacement: Schritt 5, Bild 1 von 1
    • Remove the circuit board from the front face-plate with the tumblers still attached.
    • Be careful not to remove the buttons from the front face-plate to avoid further complications.
  6. Xbox 360 Controller USB Cord Replacement: Schritt 6, Bild 1 von 1
    • Place the circuit board on a non-conductive surface with the thumb sticks facing up, and the USB cord facing you.
    • Static surfaces may damage the circuit board.
  7. Xbox 360 Controller USB Cord Replacement: Schritt 7, Bild 1 von 1
    • Turn on the soldering iron,
    • Remove the solder, which is directly to the right of the left thumb stick, from the four linear nodes by using the desoldering wick and the soldering iron.
    • Circuit board should remain in the same position as is shown in step 6.
    • Improper use of the soldering iron will result in injury.
    • Direct contact between the circuit board and soldering iron may damage the board.
  8. Xbox 360 Controller USB Cord Replacement: Schritt 8, Bild 1 von 2 Xbox 360 Controller USB Cord Replacement: Schritt 8, Bild 2 von 2
    • Remove the wire housing from the opposite side of the circuit board.
    • Do not apply excessive force on the circuit board. This will cause it to break.
  9. Xbox 360 Controller USB Cord Replacement: Schritt 9, Bild 1 von 2 Xbox 360 Controller USB Cord Replacement: Schritt 9, Bild 2 von 2
    • Connect the new housing and new wire to the back side of the circuit board. The wire should come out from the top of the controller.
    • The order of the wires (from left to right) is: black, green, white, red.
  10. Xbox 360 Controller USB Cord Replacement: Schritt 10, Bild 1 von 1
    • Repeat step 6.
  11. Xbox 360 Controller USB Cord Replacement: Schritt 11, Bild 1 von 1
    • Re-solder the four nodes (left to right) with the soldering iron and soldering wire.
  12. Xbox 360 Controller USB Cord Replacement: Schritt 12, Bild 1 von 1
    • Reassemble, and get back to gaming!
Abschluss
By following these steps, you will be able to replace your Xbox 360 controller's USB cord. Hopefully this guide is useful to you and will elongate the life capacity of your Xbox 360 controller.
35 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Bahl
930 Reputation
1 Anleitung geschrieben
Colorado Springs, Team 7-1, Mcmichael Fall 2015 Mitglied von Colorado Springs, Team 7-1, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S7G1
3 Mitglieder
2 Anleitungen geschrieben
16 Kommentare
Where did you bought the replacement wire/cord?
gatchie24 - Antwort
The first one took me 1 hour and half, the second one 20 minutes. Here are some comments.
- It was very hard to unsolder the defective USB plug. I had to use a high temperature on the solder iron, and pull the plug from the other side as I was alternating between the 4 pins.
- There are 4 pins but 5 holes on the board. Make sure to check what one is useless before unsoldering.
- It is best to dismount the controller face down and to keep it that way. The face plate has all the buttons and they will fall if you turn it upside up.
Jean-Yves Tinevez - Antwort
What happen if I disconnect the tumblers
Xander Redstorm - Antwort
Thank you for this explicitly post.
Albert Einstein - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 109
Letzte 30 Tage: 605
Insgesamt: 74,806
