Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 7.0 Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: Schritt 3, Bild 2 von 2
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Aubrey Goodwin
2.700 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-3, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Where can I order the new speaker?
Dorrie Stotko - Antwort
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 19
Insgesamt: 3,930
