Zum Hauptinhalt wechseln
GoPro Hero3+ Silver Edition Image Sensor Replacement
Was du brauchst
  1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: Schritt 1, Bild 1 von 2 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 2, Bild 1 von 1
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: Schritt 3, Bild 1 von 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 4, Bild 1 von 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: Schritt 5, Bild 1 von 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: Schritt 5, Bild 2 von 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: Schritt 5, Bild 3 von 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 6, Bild 1 von 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 6, Bild 2 von 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 8, Bild 1 von 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 8, Bild 2 von 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Patrick Cook
687 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-8, Maness Fall 2015 Mitglied von Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 744
