Zum Hauptinhalt wechseln
Lenovo Yoga 2 Pro Trackpad Replacement
Was du brauchst
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 4, Bild 1 von 1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 5, Bild 1 von 2 Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 8, Bild 1 von 1
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 9, Bild 1 von 2 Lenovo Yoga 2 Pro Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Lift the trackpad out of the computer.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Thomas Simko
2.511 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-14, Maness Fall 2015 Mitglied von Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
Where can I buy this trackpad? Mine is done.
Jorge Suarez - Antwort
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - Antwort
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 9,392
