Zum Hauptinhalt wechseln
HP Envy 23-d060qd TouchSmart Fan Replacement
Was du brauchst
  1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Fan Replacement: Schritt 3, Bild 1 von 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: Schritt 4, Bild 1 von 2 HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: Schritt 4, Bild 2 von 2
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate.
  5. HP Envy 23-d060qd TouchSmart Fan Replacement: Schritt 5, Bild 1 von 2 HP Envy 23-d060qd TouchSmart Fan Replacement: Schritt 5, Bild 2 von 2
    • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when you separate wired connections. Pulling on the wires can damage them.
  6. HP Envy 23-d060qd TouchSmart Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 8mm T15 screws from the fan.
  7. HP Envy 23-d060qd TouchSmart Fan Replacement: Schritt 7, Bild 1 von 1
    • Pull the fan loose from the computer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Zachary Dicks
1.117 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 5-10, Maness Fall 2015 Mitglied von Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 28
Insgesamt: 3,668
