Einleitung
My computer is heating up! Is it catching a fever? What can I do to keep it at its normal temperature? Replacing the fan should not be too difficult.
Was du brauchst
Use your hands to unclip the plastic snaps on the back panel of the device.
Remove the five 7.5mm T15 screws from the cover plate.
Remove the cover plate.
Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
