Zum Hauptinhalt wechseln
Lenovo Yoga 2 Pro Wireless Card Replacement
Was du brauchst
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: Schritt 1, Bild 1 von 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: Schritt 5, Bild 1 von 2 Lenovo Yoga 2 Pro Wireless Card Replacement: Schritt 5, Bild 2 von 2
    • Slide the wireless module towards the battery and lift out of the laptop.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Thomas Simko
2.511 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-14, Maness Fall 2015 Mitglied von Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 36
Insgesamt: 11,172
