Zum Hauptinhalt wechseln
Pebble Steel Vibration Motor Replacement
Was du brauchst
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: Schritt 1, Bild 1 von 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: Schritt 1, Bild 2 von 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: Schritt 1, Bild 3 von 3
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
  2. Pebble Steel Vibration Motor Replacement: Schritt 2, Bild 1 von 2 Pebble Steel Vibration Motor Replacement: Schritt 2, Bild 2 von 2
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: Schritt 3, Bild 1 von 1
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
  4. Pebble Steel Vibration Motor Replacement: Schritt 4, Bild 1 von 1
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-7, Leahy Fall 2015 Mitglied von USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - Antwort
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 3,053
