Zum Hauptinhalt wechseln
Dell Inspiron 8600 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 8600 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: Schritt 2, Bild 1 von 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: Schritt 2, Bild 2 von 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: Schritt 2, Bild 3 von 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Perry
251 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-22, Garner Spring 2011 Mitglied von Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 3,858
