Zum Hauptinhalt wechseln
Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement
Was du brauchst
  1. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement, Rear camera & Earpiece & Front camera: Schritt 1, Bild 1 von 2 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement, Rear camera & Earpiece & Front camera: Schritt 1, Bild 2 von 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 2, Bild 3 von 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 3, Bild 1 von 2 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 3, Bild 2 von 2
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
  4. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 4, Bild 3 von 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 5, Bild 1 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 5, Bild 2 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 5, Bild 3 von 3
    • Remove front camera.
  6. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 6, Bild 1 von 2 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 6, Bild 2 von 2
    • Remove earpiece.
  7. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: Schritt 7, Bild 3 von 3
    • Remove rear camera.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Witrigs
69.493 Reputation
378 Anleitungen geschrieben
2 Kommentare
where i can get the plastic bracket? my plastic bracket is broke
Ranon Kusuma - Antwort
Step 4: the flash/lamp is lighly glued to the back frame. It must be delicately unglued off before the frame can be removed.
Frédéric Leroy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 4,774
