Zum Hauptinhalt wechseln
Apple Powerbook 5300 Hard Drive Replacement
Was du brauchst
  1. Apple Powerbook 5300 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Hard Drive Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
    • Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
  5. Apple Powerbook 5300 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Apple Powerbook 5300 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the Torx #8 screws holding the hard drive case in place on the logic board.
    • Lift up on the hard drive to disconnect its ribbon cable from the logic board, just like in the previous steps.
  6. Apple Powerbook 5300 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Apple Powerbook 5300 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the four Torx #8 screws holding the hard drive to its case.
    • The hard drive can now be removed from its encasement.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Scott
155 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-30, Garner Spring 2011 Mitglied von Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
I was very surprised to find this guide and very pleased. Good work.
mayer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 20
Insgesamt: 6,149
