Zum Hauptinhalt wechseln
Nikon Coolpix S220 LCD Replacement
Was du brauchst
  1. Nikon Coolpix S220 LCD Replacement, Outer Cover: Schritt 1, Bild 1 von 1
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 LCD Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 LCD Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 LCD Replacement: Schritt 4, Bild 1 von 1
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 LCD Replacement, LCD: Schritt 5, Bild 1 von 1
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 LCD Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 LCD Replacement: Schritt 7, Bild 1 von 1
    • Slowly pull the screen from the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Shauna
798 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-32, Maness Spring 2011 Mitglied von Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
Where did you obtain the replacement LCD screen? I have two of the Coolpix's with broken LCD screens. I found your page looking for the dreaded "lens error", which the pulling on the lens idea helped me fix and now I would like to replace the cracked LCD screen in that camera. I had never thought it economically feasible. Thanks.
Roger Helbig - Antwort
Got my replacement LCD from eBay seller for very reasonable price.
The guide has you removing a couple, maybe 3 screws from the front side case, which I believe could have been left in place, but otherwise it is a good repair guide. If I had known how easy and cheap this repair was going to be, I would have done it over a year ago. I thought that I was going to have to find a repair shop (even looked and they wanted $90 per hour just for labor and did not have a price for the part(s). Glad I found the LCD on eBay and did it myself. Only took 5 minutes and IIRC, the LCD screen was less than $20 including shipping.
David Morris - Antwort
did you ever fix your camera
maya b - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 8,697
