Zum Hauptinhalt wechseln
HP Pavilion zd8000 Keyboard Replacement
Was du brauchst
  1. HP Pavilion zd8000 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion zd8000 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  4. HP Pavilion zd8000 Keyboard Replacement: Schritt 4, Bild 1 von 2 HP Pavilion zd8000 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  5. HP Pavilion zd8000 Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion zd8000 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  6. HP Pavilion zd8000 Keyboard Replacement: Schritt 6, Bild 1 von 2 HP Pavilion zd8000 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
Abschluss
Allie Menard
820 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 24-56, Amido Spring 2011 Mitglied von Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 4,093
