Zum Hauptinhalt wechseln
HP Pavilion zd8000 USB Module Replacement
Was du brauchst
  1. HP Pavilion zd8000 USB Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 USB Module Replacement: Schritt 2, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 USB Module Replacement, RAM: Schritt 3, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement, RAM: Schritt 3, Bild 2 von 2
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. HP Pavilion zd8000 USB Module Replacement: Schritt 4, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 4, Bild 2 von 2
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. HP Pavilion zd8000 USB Module Replacement: Schritt 5, Bild 1 von 1
    • Carefully slide the card out at an upward angle away from the slot.
  6. HP Pavilion zd8000 USB Module Replacement, WiFi Card Cables: Schritt 6, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement, WiFi Card Cables: Schritt 6, Bild 2 von 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  7. HP Pavilion zd8000 USB Module Replacement: Schritt 7, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 7, Bild 2 von 2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  8. HP Pavilion zd8000 USB Module Replacement, CD/Optical Drive: Schritt 8, Bild 1 von 1
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  9. HP Pavilion zd8000 USB Module Replacement: Schritt 9, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 9, Bild 2 von 2
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  10. HP Pavilion zd8000 USB Module Replacement: Schritt 10, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 10, Bild 2 von 2
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
  11. HP Pavilion zd8000 USB Module Replacement, Keyboard: Schritt 11, Bild 1 von 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  12. HP Pavilion zd8000 USB Module Replacement: Schritt 12, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 12, Bild 2 von 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  13. HP Pavilion zd8000 USB Module Replacement: Schritt 13, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 13, Bild 2 von 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  14. HP Pavilion zd8000 USB Module Replacement: Schritt 14, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 14, Bild 2 von 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
  15. HP Pavilion zd8000 USB Module Replacement, Switch Cover: Schritt 15, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement, Switch Cover: Schritt 15, Bild 2 von 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  16. HP Pavilion zd8000 USB Module Replacement: Schritt 16, Bild 1 von 1
    • Flip the laptop over.
    • Fully open the laptop.
  17. HP Pavilion zd8000 USB Module Replacement: Schritt 17, Bild 1 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 17, Bild 2 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 17, Bild 3 von 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
  18. HP Pavilion zd8000 USB Module Replacement, Screen: Schritt 18, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement, Screen: Schritt 18, Bild 2 von 2
    • Close the lid and rotate the laptop so that the vents are facing you.
    • Unscrew the two 8mm Philips screws below the hinges.
  19. HP Pavilion zd8000 USB Module Replacement: Schritt 19, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 19, Bild 2 von 2
    • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
    • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
  20. HP Pavilion zd8000 USB Module Replacement: Schritt 20, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 20, Bild 2 von 2
    • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
    • Pull gently to remove the black and grey cables from the case.
    • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
  21. HP Pavilion zd8000 USB Module Replacement: Schritt 21, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 21, Bild 2 von 2
    • Using tweezers, pull the black cable towards the display and through the hole in the casing.
  22. HP Pavilion zd8000 USB Module Replacement: Schritt 22, Bild 1 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 22, Bild 2 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 22, Bild 3 von 3
    • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
    • Lift the screen upwards to detach it from the laptop.
  23. HP Pavilion zd8000 USB Module Replacement, Top Cover: Schritt 23, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement, Top Cover: Schritt 23, Bild 2 von 2
    • With the laptop face-down, remove the eleven 8mm Philips screws.
  24. HP Pavilion zd8000 USB Module Replacement: Schritt 24, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 24, Bild 2 von 2
    • Rotate the laptop 180 degrees so the vents are facing you.
    • Unscrew the four 3mm Philips screws below the vents.
  25. HP Pavilion zd8000 USB Module Replacement: Schritt 25, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 25, Bild 2 von 2
    • Rotate the laptop 90 degrees counter-clockwise.
    • Unscrew the two 3mm Philips screws from the optical drive bay.
  26. HP Pavilion zd8000 USB Module Replacement: Schritt 26, Bild 1 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 26, Bild 2 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 26, Bild 3 von 3
    • Flip the laptop over so it is face-up with the trackpad closest to you.
    • Locate the ribbon cable directly above the track pad.
    • Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
  27. HP Pavilion zd8000 USB Module Replacement: Schritt 27, Bild 1 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 27, Bild 2 von 3 HP Pavilion zd8000 USB Module Replacement: Schritt 27, Bild 3 von 3
    • Find the ribbon cable on the LED board located at the top of the laptop.
    • You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
  28. HP Pavilion zd8000 USB Module Replacement: Schritt 28, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 28, Bild 2 von 2
    • Locate the white connector attached to a red and black cable to the right of the LED board.
    • Using tweezers, pull the white connector away from you.
  29. HP Pavilion zd8000 USB Module Replacement: Schritt 29, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 29, Bild 2 von 2
    • Unscrew the four 8mm Philips screws from the top cover.
  30. HP Pavilion zd8000 USB Module Replacement: Schritt 30, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 30, Bild 2 von 2
    • Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
    • While lifting the front end of the top cover, slide the spudger across the seam.
    • When you have reached the firewire port, it should click open.
  31. HP Pavilion zd8000 USB Module Replacement: Schritt 31, Bild 1 von 1
    • Lift the top cover from the left side to remove it completely.
  32. HP Pavilion zd8000 USB Module Replacement, USB Module: Schritt 32, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement, USB Module: Schritt 32, Bild 2 von 2
    • Locate the USB Module
    • Grip the yellow cable cover and pull it to the right to release it.
  33. HP Pavilion zd8000 USB Module Replacement: Schritt 33, Bild 1 von 2 HP Pavilion zd8000 USB Module Replacement: Schritt 33, Bild 2 von 2
    • Unscrew the 6mm Philips screw connecting the USB module to the fan.
  34. HP Pavilion zd8000 USB Module Replacement: Schritt 34, Bild 1 von 1
    • Pull the module to the right and lift it out to release it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Allie Menard
820 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 24-56, Amido Spring 2011 Mitglied von Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,532
