Zum Hauptinhalt wechseln
Sony Xperia E3 Touch Screen Replacement
Was du brauchst
Einführungsvideo
  1. Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: Schritt 1, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: Schritt 1, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: Schritt 1, Bild 3 von 3
    • Turn off the device
    • Remove the SIM and the memory cards.
    • Remove 4x rubber corners.
    • There are 6x black screws Torx T4, remove them.
  2. Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: Schritt 2, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: Schritt 2, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: Schritt 2, Bild 3 von 3
    • Use a plastic tool and separate the rear bezel.
    • Be careful for the side buttons.
  3. Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: Schritt 3, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: Schritt 3, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: Schritt 3, Bild 3 von 3
    • Disconnect the touch screen flex cable.
    • Disconnect the battery flex cable.
  4. Sony Xperia E3 Touch Screen Replacement: Schritt 4, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 4, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 4, Bild 3 von 3
    • With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes.
    • Use a thin plastic tool, like a plastic pick and start the separation from the underside.
    • Do this very slow and periodically warm the glass!
    • At the beginning you have to separate the touch screen glass from the main frame.
  5. Sony Xperia E3 Touch Screen Replacement: Schritt 5, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 5, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Now continue with a plastic card.
    • AGAIN!!! Very slowly and periodically worm the glass.
    • The LCD is thin less than a millimeter!
    • Remove the touch screen.
  6. Sony Xperia E3 Touch Screen Replacement: Schritt 6, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 6, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 6, Bild 3 von 3
    • Now is time to test the phone.
    • If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD
    • With a plastic pick gently scrape the glue.
    • With a cloth and isopropyl alcohol clean the LCD.
    • Don't use a lot of alcohol. if the liquid passes behind the LCD, will appear spots that you can't remove.
  7. Sony Xperia E3 Touch Screen Replacement: Schritt 7, Bild 1 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 7, Bild 2 von 3 Sony Xperia E3 Touch Screen Replacement: Schritt 7, Bild 3 von 3
    • On the new touch screen or on the main frame put adhesive sticker 3mm.
    • Be careful not to cover the the places for the camera, sensor, earpiece, etc.
    • Lift the logic board a little bit, so that the touch screen flex cable can pass.
    • It's easier if you can order the touch screen together with adhesive which is cut off specifically for model.
  8. Sony Xperia E3 Touch Screen Replacement: Schritt 8, Bild 1 von 1
    • Reassemble the device.
    • That's all.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.278 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.526 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 7,969
