Zum Hauptinhalt wechseln
How to Fix a Broken XLR Microphone Cable
Was du brauchst
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: Schritt 1, Bild 1 von 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: Schritt 1, Bild 2 von 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: Schritt 1, Bild 3 von 3
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: Schritt 2, Bild 1 von 1
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: Schritt 3, Bild 1 von 2 How to Fix a Broken XLR Microphone Cable: Schritt 3, Bild 2 von 2
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: Schritt 4, Bild 1 von 3 How to Fix a Broken XLR Microphone Cable: Schritt 4, Bild 2 von 3 How to Fix a Broken XLR Microphone Cable: Schritt 4, Bild 3 von 3
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: Schritt 5, Bild 1 von 2 How to Fix a Broken XLR Microphone Cable: Schritt 5, Bild 2 von 2
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Abbie Zajac
203 Reputation
1 Anleitung geschrieben
Oakland University, Team 6-3, Walwema Winter 2016 Mitglied von Oakland University, Team 6-3, Walwema Winter 2016
OAK-WALWEMA-W16S6G3
2 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 36
Letzte 30 Tage: 134
Insgesamt: 24,911
