Einleitung
The Canon Selphy CP910 is used to print pictures from a camera and WiFi connection. If there are any issues with the buttons on the printer, it may be necessary to remove them. For information regarding troubleshooting issues with the Canon Selphy CP910, go to Canon Selphy CP910 Troubleshooting.
Contact the manufacturer for inquiries about receiving parts of the Canon Selphy CP910.
Was du brauchst
Turn the printer over.
Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
Turn the device around and remove the "open" lid.
Gently bend the lid and remove it from its hinges.
Turn the device back over and lift the top panel up.
Disconnect the ribbon cables leading to the LCD screen.
Pull the top panel off.
Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
