Zum Hauptinhalt wechseln
Motorola Lapdock 100 Lower Case Replacement
Was du brauchst
  1. Motorola Lapdock 100 Lower Case Replacement, Lower Case: Schritt 1, Bild 1 von 2 Motorola Lapdock 100 Lower Case Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Lower Case Replacement: Schritt 2, Bild 1 von 1
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Lower Case Replacement: Schritt 3, Bild 1 von 1
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Lower Case Replacement: Schritt 4, Bild 1 von 2 Motorola Lapdock 100 Lower Case Replacement: Schritt 4, Bild 2 von 2
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Lower Case Replacement: Schritt 5, Bild 1 von 2 Motorola Lapdock 100 Lower Case Replacement: Schritt 5, Bild 2 von 2
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Lower Case Replacement: Schritt 6, Bild 1 von 3 Motorola Lapdock 100 Lower Case Replacement: Schritt 6, Bild 2 von 3 Motorola Lapdock 100 Lower Case Replacement: Schritt 6, Bild 3 von 3
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Lower Case Replacement: Schritt 7, Bild 1 von 2 Motorola Lapdock 100 Lower Case Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
This helps with the opening up but what about inside? I need to replace the charging port and can find no part number or a decent marking.
Ian Leigh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 369
