Zum Hauptinhalt wechseln
Removing Minolta X-370 Bottom Cover
Was du brauchst
  1. Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: Schritt 1, Bild 1 von 2 Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: Schritt 1, Bild 2 von 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: Schritt 2, Bild 1 von 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: Schritt 3, Bild 1 von 2 Removing Minolta X-370 Bottom Cover, Bottom Cover: Schritt 3, Bild 2 von 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: Schritt 4, Bild 1 von 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: Schritt 5, Bild 1 von 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick
525 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-7, Regan Spring 2011 Mitglied von Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 32
Insgesamt: 10,769
