Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Speakal iPanda zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Speakal iPanda Teardown, Speakal iPanda Teardown: Schritt 1, Bild 1 von 1
    • The happy Panda
  2. Speakal iPanda Teardown: Schritt 2, Bild 1 von 3 Speakal iPanda Teardown: Schritt 2, Bild 2 von 3 Speakal iPanda Teardown: Schritt 2, Bild 3 von 3
    • Flip it to find the screws.
    • Unscrew the four Phillips #0 screws.
  3. Speakal iPanda Teardown: Schritt 3, Bild 1 von 2 Speakal iPanda Teardown: Schritt 3, Bild 2 von 2
    • Be careful with the cables of the subwoofer.
  4. Speakal iPanda Teardown: Schritt 4, Bild 1 von 2 Speakal iPanda Teardown: Schritt 4, Bild 2 von 2
    • He look like this on his insides.
    • there is a little lock on the sides.
    • Don't forget these screws too.
  5. Speakal iPanda Teardown: Schritt 5, Bild 1 von 2 Speakal iPanda Teardown: Schritt 5, Bild 2 von 2
    • Opening the sandwich.
    • Don't forget the cables!
  6. Speakal iPanda Teardown: Schritt 6, Bild 1 von 3 Speakal iPanda Teardown: Schritt 6, Bild 2 von 3 Speakal iPanda Teardown: Schritt 6, Bild 3 von 3
    • It doens't look like a panda anymore.
  7. Speakal iPanda Teardown: Schritt 7, Bild 1 von 1
    • Removing the board, it's all done.
  8. Speakal iPanda Teardown: Schritt 8, Bild 1 von 2 Speakal iPanda Teardown: Schritt 8, Bild 2 von 2
    • Poor panda...
paulostool
121 Reputation
1 Anleitung geschrieben
3 Kommentare
Hi!
I have just wondered about tweeter type.
I have a pig, bud one of it's tweeters is dead.
Do you have any idea how to get a replacement tweeter?
THX!!
sonofhoegaarden - Antwort
Hello All,
Please can you assist me with sourcing a amplifier board for the Shox Panda as above in the panda tear down. My panda is supplying 12 Vots DC to the woofer. Thanks very much.
Peter Boucher - Antwort
Hi Peter, you may consider swapping the actual CD7377CZ Audio Amp for a ST Microelectronics TDA7375V, and probably the RM2576-5.0 voltage regulator with a Texas Instruments LM2576-5.0, both of which are drop-in replacement (as parts are chinese knock-offs).
Cheers !
grogcw - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 5,060
