Einleitung
This guide will give user step by step instructions on how to replace the screen of the camera.
Was du brauchst
First remove the battery and SD Card
Then use the screwdriver to remove the 6 screws that need to be removed to take off the outer case.
2 screws are located on the bottom.
2 screws are located on the left side (near the HDMI port).
2 screws are located on the right side (opposite side of the HDMI port).
Once the screws are removed, use the blue opening tool to open the back case from the sides - it should come off easily.
Use the screwdriver to remove the small silver screw holding down the control panel (located on the bottom right next to the screen).
Use the blue opening tool to lift up the control panel from where the screw was just removed.
Connect the new screen by gently pressing the display cable on to its connector (on the motherboard).
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I previously mentioned that I had a sticky substance seeping from my camera. I spent quite a long time, using acetone to remove this fluid stuff from the LCD and the clear screen which was stuck to the LCD. It was not an easy task because of the quick evaporation of the acetone. Now, must I stick the LCD and the part/clear lens together? If so, with what glue? The second part to my question is that there was a second plate (?) with a rubbery surface on one side and I did not notice which side faces the lens because it fell out before I noticed it, rubber or plain metal? Any help will be appreciated. :-(
Is it normal from such a renowned company? I even got some instability in installed programs.
