Zum Hauptinhalt wechseln
Dremel 4000 Power Cord Replacement
Was du brauchst
  1. Dremel 4000 Power Cord Replacement, Back Case: Schritt 1, Bild 1 von 2 Dremel 4000 Power Cord Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Power Cord Replacement: Schritt 3, Bild 1 von 2 Dremel 4000 Power Cord Replacement: Schritt 3, Bild 2 von 2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Power Cord Replacement: Schritt 6, Bild 1 von 1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Power Cord Replacement, Power Cord: Schritt 7, Bild 1 von 2 Dremel 4000 Power Cord Replacement, Power Cord: Schritt 7, Bild 2 von 2
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Dremel 4000 Power Cord Replacement: Schritt 8, Bild 1 von 1
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Dremel 4000 Power Cord Replacement: Schritt 9, Bild 1 von 1
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
  10. Dremel 4000 Power Cord Replacement: Schritt 10, Bild 1 von 1
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
John Cobb
1.689 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 15-4, Remmell Spring 2016 Mitglied von USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Mitglieder
13 Anleitungen geschrieben
Ein Kommentar
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 63
Insgesamt: 5,718
