Einleitung
In the following steps you will access the electrical assembly, and remove the positive and negative wires that connect the power cord to the assembly.
Was du brauchst
Start by removing the housing cap by unscrewing it.
Next, unscrew the now exposed collet nut while holding down the shaft lock button.
Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
Use your hands to carefully remove the back casing so that none of the components fall out.
To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
Each wire is fed through a small opening on the circuit board and held with a flat head screw.
Loosen the screw just enough to remove the wire by gently pulling it with your hand.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Super handy guide after my guide dog decided to chew through the cable!
