Einleitung
We will be replacing the battery in the Garmin Fenix 2 watch. You should have a Torx T9 screwdriver on hand and a nylon spudger.
Was du brauchst
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
can you tell us exactly which battery should be used? Thanks in advance!
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
