Zum Hauptinhalt wechseln
Lenovo Ideapad Flex 15 Bottom Panel Replacement
Was du brauchst
  1. Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: Schritt 1, Bild 1 von 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: Schritt 1, Bild 2 von 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 2, Bild 2 von 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 3, Bild 1 von 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 3, Bild 2 von 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 3, Bild 3 von 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 4, Bild 1 von 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 5, Bild 1 von 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 5, Bild 2 von 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 5, Bild 3 von 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 6, Bild 1 von 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: Schritt 6, Bild 2 von 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Brent
804 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 2,839
