Einleitung
This guide shows how to replace Axess SPBT1031 Subwoofer. Replacing the subwoofer is moderate difficulty and it'll take about 15 minutes to replace. Below is the step-by-step guide to replacing the subwoofer.
Was du brauchst
Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
Use a metal spudger to remove the mesh speaker cover by wedging the narrow end into the center of the outer edge of the mesh touching the red plate.
Remove four 5.5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
If the screws are difficult to remove, use the tweezers to twist and pick them out.
Separate the red plate from the black face plate by removing the black plate from the tube and pushing on the inside of the subwoofer.
To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Use a desoldering pump to remove the liquid solder from the terminals.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
