Einleitung
This guide demonstrates how to replace the case of your Palm m105. The case on the Palm m105 can be easily removed, and a replacement shell casing can be used to replace your damaged one.
Before you begin this repair, power off your device and make sure it's unplugged from the charger.
Was du brauchst
Remove the protective flip lid of the device. Open the lid and pull.
Remove the batteries by opening the battery compartment on the back of the device.
Remove one battery at a time.
Using a T-5 Torx screwdriver, remove all four screws at the back of the device by turning them counterclockwise. A sample screwdriver is located here.
This is what the case of the device should look like when completed.
You can purchase a new shell here: Replacement Shell Palm m105
