Zum Hauptinhalt wechseln
Dell Netbook e6400 Tastiera Replacement
Was du brauchst
  1. Dell Netbook e6400 Tastiera Replacement, Tastiera: Schritt 1, Bild 1 von 1
    • Rimuovere batteria
  2. Dell Netbook e6400 Tastiera Replacement: Schritt 2, Bild 1 von 2 Dell Netbook e6400 Tastiera Replacement: Schritt 2, Bild 2 von 2
    • Estrarre la card dalle slot tirando la linguetta
    • Facendo leva sugli agganci in plastica si sgancia nella parte anteriore la linea di tasti in alto che danno accesso alle viti fissaggio tastiera
  3. Dell Netbook e6400 Tastiera Replacement: Schritt 3, Bild 1 von 1
    • Fare leva sotto per estrarre la linea di tasti superiore
  4. Dell Netbook e6400 Tastiera Replacement: Schritt 4, Bild 1 von 3 Dell Netbook e6400 Tastiera Replacement: Schritt 4, Bild 2 von 3 Dell Netbook e6400 Tastiera Replacement: Schritt 4, Bild 3 von 3
    • Svitare le due viti a croce che tengono la tastiera fissata al corpo notebook
    • Nuova riga.itilizzare la linguetta nera per tirare indietro e verso l'altro per sganciare la tastiera
Abschluss
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Smilzo
11.276 Reputation
39 Anleitungen geschrieben
2 Kommentare
ciao and thanks for this guide @smilzo !
I recently had to re-seat the keyboard, which is a common trick for old Dell laptops when the keyboards starts having issues and types nonsense. However after putting it back together, the keyboard doesn’t light up anymore. what am I doing wrong? did I miss a connector?
alfx - Antwort
hi, sorry for what happened, try to disassemble the keyboard again and check that the connectors are inserted well on the correct side and that the cable has not broken.  good luck
Smilzo -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 29
Insgesamt: 1,570
