Zum Hauptinhalt wechseln
Install iJDMTOY Volkswagen Jetta LED Daytime Running Light LED Daytime Running Lights
Was du brauchst
  1. Install iJDMTOY Volkswagen Jetta LED Daytime Running Light LED Daytime Running Lights, LED Daytime Running Lights: Schritt 1, Bild 1 von 1
    • First find the Daytime Running Lights using this diagram.
    • Make sure you pull out the right bulb.
  2. Install iJDMTOY Volkswagen Jetta LED Daytime Running Light LED Daytime Running Lights: Schritt 2, Bild 1 von 1
    • Take out the adapter that holds the stock incandescent light bulb in place.
  3. Install iJDMTOY Volkswagen Jetta LED Daytime Running Light LED Daytime Running Lights: Schritt 3, Bild 1 von 1
    • Remove the oem light bulb by twisting the bulb and then replace it with your new iJDMTOY LED Daytime Running Lights.
  4. Install iJDMTOY Volkswagen Jetta LED Daytime Running Light LED Daytime Running Lights: Schritt 4, Bild 1 von 1
    • Put everything back together and enjoy your new LED daytime running lights.
Abschluss
As you can see installation was a breeze and very straight forward. In no time, you can have your new iJDMTOY LED Daytime Running Lights installed in no time. You'll add a very luxurious look to the front of the car that many people will love.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Wu
3.357 Reputation
23 Anleitungen geschrieben
Ein Kommentar
Legit essay writing service is what I got when I used this company. I had a tight deadline and they were able to deliver on time with great quality. I highly recommend this company to anyone looking for a reliable and professional writing service.
Lila Kerr - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 78
Insgesamt: 7,391
