Zum Hauptinhalt wechseln
HTC Wizard 200 Motherboard Replacement
Was du brauchst
  1. HTC Wizard 200 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Motherboard Replacement, Back Panel: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $3.99
    Kaufen
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Motherboard Replacement: Schritt 3, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement: Schritt 3, Bild 2 von 2
    Spudger
    $3.99
    Kaufen
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Motherboard Replacement: Schritt 4, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement: Schritt 4, Bild 2 von 2
    T5 Torx Screwdriver
    $5.49
    Kaufen
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Motherboard Replacement: Schritt 5, Bild 1 von 3 HTC Wizard 200 Motherboard Replacement: Schritt 5, Bild 2 von 3 HTC Wizard 200 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Motherboard Replacement: Schritt 6, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    Spudger
    $3.99
    Kaufen
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Motherboard Replacement: Schritt 8, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement: Schritt 8, Bild 2 von 2
    Kaufen
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Motherboard Replacement: Schritt 10, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement: Schritt 10, Bild 2 von 2
    Spudger
    $3.99
    Kaufen
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Motherboard Replacement: Schritt 11, Bild 1 von 2 HTC Wizard 200 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
Abschluss
Kyle Champ
225 Reputation
12 Anleitungen geschrieben
Cal Poly, Team 20-27, Maness Fall 2011 Mitglied von Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 1,114
