Zum Hauptinhalt wechseln
Samsung Galaxy Prevail Rear Camera Lens Replacement
Was du brauchst
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: Schritt 1, Bild 1 von 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: Schritt 2, Bild 1 von 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: Schritt 3, Bild 1 von 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: Schritt 4, Bild 1 von 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: Schritt 5, Bild 1 von 1
    • Replace the secondary rear panel which has the camera lens attached.
Abschluss
USF Tampa, Team 17-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 264
