Einleitung
Using this guide you will replace the camera lens fixing hardware related camera issues such as scratches or cracks.
Was du brauchst
Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
