Zum Hauptinhalt wechseln
BlackBerry Curve 8900 Case Replacement
Was du brauchst
  1. BlackBerry Curve 8900 Case Replacement, Removing the Case: Schritt 1, Bild 1 von 2 BlackBerry Curve 8900 Case Replacement, Removing the Case: Schritt 1, Bild 2 von 2
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: Schritt 2, Bild 1 von 1
    • Using a small plastic opening tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: Schritt 3, Bild 1 von 1
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: Schritt 4, Bild 1 von 1
    • Remove the midframe from the phone.
  5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: Schritt 5, Bild 1 von 2 BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: Schritt 5, Bild 2 von 2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Abschluss
Use the new case and reassemble the phone by doing the instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Renae Bishop
68 Reputation
4 Anleitungen geschrieben
Cuesta, Team 1-3, Zipperian Fall 2011 Mitglied von Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 3,333
