Zum Hauptinhalt wechseln
Acer AL1916 Outer Case Replacement
Was du brauchst
  1. Acer AL1916 Outer Case Replacement, Stand: Schritt 1, Bild 1 von 1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Outer Case Replacement: Schritt 2, Bild 1 von 2 Acer AL1916 Outer Case Replacement: Schritt 2, Bild 2 von 2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Outer Case Replacement: Schritt 3, Bild 1 von 2 Acer AL1916 Outer Case Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Outer Case Replacement, Outer Case: Schritt 4, Bild 1 von 2 Acer AL1916 Outer Case Replacement, Outer Case: Schritt 4, Bild 2 von 2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Outer Case Replacement: Schritt 5, Bild 1 von 3 Acer AL1916 Outer Case Replacement: Schritt 5, Bild 2 von 3 Acer AL1916 Outer Case Replacement: Schritt 5, Bild 3 von 3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Outer Case Replacement: Schritt 6, Bild 1 von 2 Acer AL1916 Outer Case Replacement: Schritt 6, Bild 2 von 2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
Abschluss
Keith
351 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 20-26, Maness Fall 2011 Mitglied von Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 1,246
