Zum Hauptinhalt wechseln
Dell Dimension 4600 Fan Replacement
  1. Dell Dimension 4600 Fan Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Fan Replacement: Schritt 2, Bild 1 von 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Fan Replacement: Schritt 3, Bild 1 von 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Fan Replacement, Fan: Schritt 4, Bild 1 von 1
    • Lay the computer flat on it's side so that you are looking down at all of the components.
    • Locate the fan and its black, red, and white power cable.
  5. Dell Dimension 4600 Fan Replacement: Schritt 5, Bild 1 von 1
    • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
  6. Dell Dimension 4600 Fan Replacement: Schritt 6, Bild 1 von 1
    • Locate the release clip on the side of the fan and hold it down with your thumb.
  7. Dell Dimension 4600 Fan Replacement: Schritt 7, Bild 1 von 1
    • While holding the release clip down, look on the outside of the case where the fan lies.
    • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Tim
76 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-10, Regan Fall 2011 Mitglied von Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 5,888
