Zum Hauptinhalt wechseln
Acer Aspire 5734z-4836 Keyboard Replacement
  1. Acer Aspire 5734z-4836 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 3, Bild 1 von 2 Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 5, Bild 1 von 2 Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 6, Bild 1 von 3 Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 6, Bild 2 von 3 Acer Aspire 5734z-4836 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
CSU Fullerton, Team 2-3, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,426
