Zum Hauptinhalt wechseln
Makita XPH01 Drill Brush Replacement
Was du brauchst
  1. Makita XPH01 Drill Brush Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Drill Brush Replacement: Schritt 2, Bild 1 von 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Drill Brush Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Drill Brush Replacement, Drill Brush: Schritt 4, Bild 1 von 1
    • Hold the drill upright with the back panel facing you.
  5. Makita XPH01 Drill Brush Replacement: Schritt 5, Bild 1 von 2 Makita XPH01 Drill Brush Replacement: Schritt 5, Bild 2 von 2
    • Unscrew two 18mm screws from the back panel with the Phillips PH2 screwdriver.
  6. Makita XPH01 Drill Brush Replacement: Schritt 6, Bild 1 von 2 Makita XPH01 Drill Brush Replacement: Schritt 6, Bild 2 von 2
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  7. Makita XPH01 Drill Brush Replacement: Schritt 7, Bild 1 von 3 Makita XPH01 Drill Brush Replacement: Schritt 7, Bild 2 von 3 Makita XPH01 Drill Brush Replacement: Schritt 7, Bild 3 von 3
    • Hold the drill so the back end is facing toward you.
    • Use the spudger to lift the spring clip out of the back notch.
    • Pull the spring clip forward and rest it in the front notch.
  8. Makita XPH01 Drill Brush Replacement: Schritt 8, Bild 1 von 2 Makita XPH01 Drill Brush Replacement: Schritt 8, Bild 2 von 2
    • Use the tweezers to pull the drill brush away from the sleeve.
  9. Makita XPH01 Drill Brush Replacement: Schritt 9, Bild 1 von 3 Makita XPH01 Drill Brush Replacement: Schritt 9, Bild 2 von 3 Makita XPH01 Drill Brush Replacement: Schritt 9, Bild 3 von 3
    • Use the plastic opening tool to release the clip connected to the drill brush.
    • Separate the drill brush away from the clip.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Herwatt
984 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 15-4, Livingston Fall 2016 Mitglied von Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Mitglieder
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 20
Insgesamt: 5,830
