Zum Hauptinhalt wechseln
Insignia NS-HD01A Battery Replacement
Was du brauchst
  1. Insignia NS-HD01A Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the rubber screw caps using the pointed tip of the Spudger.
  2. Insignia NS-HD01A Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
  3. Insignia NS-HD01A Battery Replacement: Schritt 3, Bild 1 von 2 Insignia NS-HD01A Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to pry open the back cover.
    • Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
  4. Insignia NS-HD01A Battery Replacement: Schritt 4, Bild 1 von 3 Insignia NS-HD01A Battery Replacement: Schritt 4, Bild 2 von 3 Insignia NS-HD01A Battery Replacement: Schritt 4, Bild 3 von 3
    • Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
  5. Insignia NS-HD01A Battery Replacement: Schritt 5, Bild 1 von 2 Insignia NS-HD01A Battery Replacement: Schritt 5, Bild 2 von 2
    • Use the flat side of the Spudger to pry the battery out of the back cover.
    • Insert the replacement battery into the back cover.
    • Reassemble the radio, making sure to reconnect the battery cable.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Joel Najmon
152 Reputation
1 Anleitung geschrieben
IUPUI, Team 2-2, Wilson Fall 2016 Mitglied von IUPUI, Team 2-2, Wilson Fall 2016
IUPUI-WILSON-F16S2G2
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,019
