Zum Hauptinhalt wechseln
Samsung DV180F Repair Battery Replacement
Was du brauchst
  1. Samsung DV180F Repair Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung DV180F Repair Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: Schritt 3, Bild 1 von 2 Samsung DV180F Repair Battery Replacement: Schritt 3, Bild 2 von 2
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: Schritt 4, Bild 1 von 1
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
Abschluss
maria
244 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 14-4, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 365
