Einleitung
Prerequisite Only
This guide is a prerequisite to access components found in the base of the laptop. It is multi-step and involves removing several pieces and screws, so be sure to keep track of everything you remove.
Was du brauchst
Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
Slide and hold the left latch below the battery.
While holding this latch in place, pry the battery up from its bottom edge.
Lift the old battery out of its compartment.
Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
Pull the blue keyboard ribbon cable from the ZIF connector.
Begin with the laptop placed on its bottom and the empty keyboard space facing you.
Locate the tape on the upper left of the laptop.
Peel off the tape, covering the red-and-black wire connector and the white-and-black speaker wires.
Gently disconnect the red-and-black wire connector and the white-and-black speaker wires from the upper-left.
Remove the 5 screws in the middle of the laptop using a #00 Phillips Screwdriver.
Disconnect the two blue and white ribbons by applying pressure downward and pushing them out of their sockets.
Remove the four screws from the upper corners of the laptop using a Phillips #00 screwdriver.
The two metal and two plastic connectors will come free. Save them in a safe place.
Remove the single screw next to the right hinge with a #00 Phillips Screwdriver.
Remove the fifteen screws from the back of the laptop with a Phillips #00 Screwdriver.
Remove the two screws on the left and bottom of the circuit board with a #00 Phillips Screwdriver.
Disconnect the black and white wires on the small circuit board by gently pulling them out of their sockets.
Remove the four screws from the metal piece beneath the circuit with a Phillips #000 Screwdriver.
Gently extract the black and white wires. They will pull free from the base through the hole in the upper left corner.
