Einleitung
This disassembly will show you how to remove the logic board as well as the lcd.
Was du brauchst
On the back there is a slider that locks the back cover on slide this over to unlock it.
Remove the 3 torx screws on both sides.
Now remove one more torx screw on the bottom.
Use the pry tool and insert in between the black and white plastic. Slide across all sides to unlock the clips holding it together.
Now all that is left is the digitizer frame holding the digitizer.
To remove a broken digitizer heat the front edges of this frame to soften the digitizer adhesive and pry away from the frame.
Thats it now just follow these steps in reverse to put your phone back together.
5 Kommentare
Brilliant! Many thanks. Things to watch: the volume rocker and on switch tend to fall out, so secured them to the back with a little bit of masking tape while I reassembled. Helped to slightly lift one end of the motherboard so the case can go around the USB power socket. After that it fits back together with only minor persuasion.
Hi,
my Search "button" stop lightning. The other 3 "buttons" are ok.
Did someone know the reason?
Thank you!
Help! I bought a t5 torx screwdriver to open my motorola and the screwdriver seems too smal! Wtf? Many dismount video says that this is a t5 model, I don't understand...
can you mark ram on that board ?
