Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Huawei Ascend zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Huawei Ascend  Teardown, Opening the phone: Schritt 1, Bild 1 von 1
    • First you want to flip the Huawei Ascend over to its back side.
    • When you are done flipping it over you want to take the back part of the phone off.
  2. Huawei Ascend  Teardown, disassembling the phone: Schritt 2, Bild 1 von 1
    • You want to use a Phillips 0 Screwdriver to remove 4 little screws.
    • The screws are found on the top corners of the phone and the bottom corners of the phone.
  3. Huawei Ascend  Teardown, disassembling the phone: Schritt 3, Bild 1 von 1
    • Now you want to take the last two screws from the right and left side of the phone to separate the front from the back.
  4. Huawei Ascend  Teardown, separating the two phone parts: Schritt 4, Bild 1 von 1
    • Now you want to use a spudger to separate the front from the back.
  5. Huawei Ascend  Teardown, the motherboard: Schritt 5, Bild 1 von 1
    • Now you should see the motherboard and other parts like camera.
juan Gonzalez
161 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,650
