Zum Hauptinhalt wechseln
1998-2002 Honda Accord Headlight Disconnect Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
  1. 1998-2002 Honda Accord Headlight Disconnect Replacement, Headlight Disconnect: Schritt 1, Bild 1 von 3 1998-2002 Honda Accord Headlight Disconnect Replacement, Headlight Disconnect: Schritt 1, Bild 2 von 3 1998-2002 Honda Accord Headlight Disconnect Replacement, Headlight Disconnect: Schritt 1, Bild 3 von 3
    • Pull on the hood release lever just inside the passenger door to pop the hood.
    • Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
    • Insert the hood prop rod into the hole in the hood marked with an arrow.
  2. 1998-2002 Honda Accord Headlight Disconnect Replacement: Schritt 2, Bild 1 von 2 1998-2002 Honda Accord Headlight Disconnect Replacement: Schritt 2, Bild 2 von 2
    • Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
    • Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
    • If needed, you can disconnect the air intake (next to the battery) to get some extra wiggle room in order to detach the head light connector on the passenger side. If you remove the air intake, be sure to plug both sides with a clean, lint-free cloth so that nothing gets inside while you work.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 657
