Einleitung
PRE-REQ ONLY!
Pull on the hood release lever just inside the passenger door to pop the hood.
Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
Insert the hood prop rod into the hole in the hood marked with an arrow.
Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
