Zum Hauptinhalt wechseln
HP Pavilion dm4-2015dx Keyboard Replacement
Was du brauchst
  1. HP Pavilion dm4-2015dx Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Turn off the device, disconnect it from all power, and remove the battery.
    • Remove the two highlighted screws to release the memory cover.
  2. HP Pavilion dm4-2015dx Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dm4-2015dx Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the two highlighted screws to release the hardware cover.
    • Remove the two screws highlighted in the 2nd image to release the hard drive cover.
  3. HP Pavilion dm4-2015dx Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the screws (as shown in pic), these two screws secure the HP keyboard.
    • Use a flathead screwdriver to release the highlighted keyboard tabs with ease.
  4. HP Pavilion dm4-2015dx Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Turn the device right-side up and pull the keyboard frame upward along the top row of keys. There are Four (4) protruding male clips that engage along this top edge. Use a flathead screwdriver or similar tool to pry the keyboard from the frame.
    • Locate and remove the lockdown cable and unlock the keyboard cables. When prying the keyboard up, you will find resistance as a small 2 inch x 1/4 inch strip of double face tape is used to further hold the keyboard in place. (Depending upon the age of the laptop, it may require additional pulling strength to break the tapes bond.)
    • Slide out the keyboard cable and install a new HP Pavilion DM4 keyboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob Meloche
597 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 6-1, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-1, Martin Fall 2016
UMASSD-MARTIN-F16S6G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 2,781
