Zum Hauptinhalt wechseln
Motorola Defy Display Assembly Replacement
Was du brauchst
  1. Motorola Defy Display Assembly Replacement, Display Assembly: Schritt 1, Bild 1 von 2 Motorola Defy Display Assembly Replacement, Display Assembly: Schritt 1, Bild 2 von 2
    • Remove the battery cover and the battery itself.
  2. Motorola Defy Display Assembly Replacement: Schritt 2, Bild 1 von 2 Motorola Defy Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Motorola Defy Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Motorola Defy Display Assembly Replacement: Schritt 4, Bild 1 von 3 Motorola Defy Display Assembly Replacement: Schritt 4, Bild 2 von 3 Motorola Defy Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  5. Motorola Defy Display Assembly Replacement: Schritt 5, Bild 1 von 3 Motorola Defy Display Assembly Replacement: Schritt 5, Bild 2 von 3 Motorola Defy Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  6. Motorola Defy Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  7. Motorola Defy Display Assembly Replacement: Schritt 7, Bild 1 von 1
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  8. Motorola Defy Display Assembly Replacement: Schritt 8, Bild 1 von 3 Motorola Defy Display Assembly Replacement: Schritt 8, Bild 2 von 3 Motorola Defy Display Assembly Replacement: Schritt 8, Bild 3 von 3
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 5,704
