Einleitung
How to remove the hard drive, along with its cable and bracket from your computer.
Was du brauchst
Turn the G4 over.
Remove the eight T8 Torx screws from the lower case.
Using your thumbs, slide the lower case away from you.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
