Zum Hauptinhalt wechseln
How to a Fix a Microwave Oven
Was du brauchst
Einführungsvideo
  1. How to a Fix a Microwave Oven, Magnetron, capacitor, fuse or diode.: Schritt 1, Bild 1 von 1
    • Don't forget to read the video description on YouTube here: https://youtu.be/WAf18e8sW4E
    • Be sensible! Take precautions like not powering it up uncovered, allowing time for high voltages to discharge. See the video description on YouTube and take note of safety advice. Don't be afraid, but just be sensible.
Abschluss
A standard microwave oven is actually a simple device comprising of a transformer, diode, capacitor, a fuse and the magnetron valve. All can be tested and replaced to fix a non heating oven. Watch the video.
27 weitere Nutzer:innen haben diese Anleitung absolviert.
jon
2.949 Reputation
22 Anleitungen geschrieben
13 Kommentare
Very simple,that mean very good
eugen - Antwort
My Whirlpool over the counter microwave which is giving me no problems at all it is only 2 years old. As I was heating up my dinner it worked fine I heated Something else up then all of a sudden it tells me to close the door and push start and when I push start it just clicks and does nothing else everything else on the microwave seems to be working
mddixiedarlin - Antwort
How about replacing a wave guide with a hole burned through it? (arcing)
Whirlpool small microwave.
Hank - Antwort
That star screw head is actually called a Torx security screw, the pin in the middle is what makes it a security screw. A mating Torx bit or driver of the appropriate size. You can buy a set of them or a combination set with standard from GearBest from the UK. They are fairly common in the U.S. In Dollars, they cost around 8.00-20.00. eBay is a good source, also. Thank you for enlightening me on what to look for and expect. My 15-year-old Panasonic has been flawless, until tonight.
Ron LHeureux - Antwort
Lg convection microven some times re start after 2 seconds 10 seconds
Manas Guchait - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 20
Letzte 7 Tage: 159
Letzte 30 Tage: 702
Insgesamt: 38,187
